Disables the Smart Redundancy feature.
| port_list | Specifies one or more ports or slots and ports. |
Enabled.
The Smart Redundancy feature works in concert with the software-controlled redundant feature. When Smart Redundancy is disabled, the switch attempts only to reset the primary port to active if the redundant port fails. That is, if you disable Smart Redundancy, the traffic does not automatically return to the primary port once it becomes active again; the traffic continues to flow through the redundant port even after the primary port comes up again.
The following command disables the Smart Redundancy feature on ports 1 through 4 on a switch:
disable smartredundancy 1-4
This command was available in ExtremeXOS 11.1.
